Is there anyway way to check a code without a scanner. My check engine light came on came on and I don’t have access to a scanner. 2011 Malibu 2.4 105,000m. Thanks
You can take the car to AutoZone or similar parts store and usually get a free code read. Make sure they give you the actual code not just a verbal summary.
I'll add bring something to write with and on as there may be more than one code.
Get it fixed, part is not expensive, Actuator Solenoid is a common part to fail. Bookmark this site , Engine-Codes.com so you can learn about engine codes if you are going to work on your own car. Below is their answer.
P0010 CHEVROLET Possible Causes
What does this mean?
  • Dirty Oil
  • Low engine oil level
  • Faulty Intake Camshaft Position Actuator Solenoid
  • Intake Camshaft Position Actuator Solenoid harness is open or shorted
  • Intake Camshaft Position Actuator Solenoid circuit poor electrical connection
  • Faulty Engine Control Module (ECM)
