Crutchfield sent me my ReaR deck 6 by 9 speakers. photos link
The pair of crutchfield boston acoustics 6 by 9 rear deck speakers arrived on sat. I will install them this week. They send email instructions and pictures. If anyone wants the pictures send me a pm. Here are the written instructions.
"Hello,
I am attaching some pictures and here are the basic written instructions.
Panel tool, 13mm SRE, small flat blade screwdriver, right-angle 7mm driver
1. Pull up on front edge of rear seat cushion to release two (2) clips then lift cushion up and
towards front of vehicle to remove.
2. Fold down rear seat backs.
3. Remove four (4) 13mm bolts from seat back latches.
4. Pull out on seat back frame, then pry out two (2) clips behind frame.
5. Starting at top edge, pry out on rear pillar trim panel to release clip, then disconnect safety
strap. Pry pillar trim panel away from lower side panel and remove pillar trim.
6. Pry lower side panel away from body to release one (1) clip.
7. Repeat steps 5-6 on opposite side.
8. Pull up on front edge of rear deck panel, disconnect third brake light harness (located on
driver's side near rear glass). Pull rear deck panel towards front of vehicle, work seat belt
through deck panel, then remove deck panel.
9. Remove one (1) 7mm screw securing speaker to rear deck, lift up on speaker, disconnect
harness and remove.
Difficulty Rating: 2 (Must use self-tapping screws to mount aftermarket speaker.)
Thank you,
Conner "
All the quotes are from crutchfield.
The pictures are not as clear as I would like, but If anyone wants them let me know. I purchased the boston acoustics s95 6 by 9 inch speakers they are 1/10 of an inch too big. I may need to file it a bit. I purchased them because they are lower powered and I am keeping the head deck in. They cost 129. link for the speakers
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=boston+acoustics+s95&i=065S95
This size fits but costs 199 and could use more power if your are adding an amp or better head deck these are good.
http://www.crutchfield.com/App/Prod...DORID065&searchdisplay=Boston+Acoustics&tp=91
"Hello,
harness and remove.
Thank you,
Conner "
