So I recently purchased a 2011 Malibu, it has the 2.4l Ecotec. It runs and drives fine (well as good as it can, being this is how I got it) however there is a steady check engine light that flashes every hundred miles or so, and I can feel a slight very almost unnoticable shake at idle, and when light is scanned it only comes back as a cylinder 2 misfire. I've already went through and replaced the plug and coil for the second cylinder from the far left with no change in engine light, or how it drives, check engine light stayed for cylinder 2 misfire. I've read some info here and there about the plug/injector wiring as well as a fault map sensor. My question to you more knowledgeable folk is what would be the next step in the troubleshooting process for a cylinder 2 misfire
