There is increasing activity on here about detailing, and I had mentioned listing/providing my car washing method. I've also been wanting to know what everyone uses to keep THEIR cars clean!
When i was thinking about it, I realized that I really rely more on the specific car I'm going to detail, or if it's mine then what condition it's in/been through since the last wash, so there isn't really a cut and dry laundry list of "15 steps" or something I could list. So, I'll list out some of my favorite methods(and a few products) for each job, because I choose based on what I have supply-wise keeping the above condition in mind.
Hopefully you'll pick up some things along the way, share what I may have missed, and it'll help narrow down your own personal method as well as mine. Advice I've gotten, and hopefully will get here, always opens my eyes to some new tricks and shifts how I go about things...
A Normal Car Wash:
Pre-Rinse --
Hose down the entire car, bottom to top with a light stream or no nozzle. If the car has gone a long while between washings, spray on Optimum No Rinse(ONR) Car Wash in 32:1 dilution via a spray bottle to start to loosen/lubricate the dirt. (Hint: If you're in the sun and it's unavoidable, give the car a much longer rinse at first to cool the paint a bit.)
Wash --
I use a Gilmour Foam Gun with Meguiar's Gold Class Car Wash and foam the car down. Then I use a bucket with 2oz. ONR and 3 Gallons of Water with a ProLine(Lowe's) Grout Sponge to wash the paint, flipping the sponge halfway through each panel, and washing/squeezing out the sponge after each panel.
Rinse --
After a solid rinse with a medium spray from the hose, use a nozzle for your hose that can put out a solid stream without air bubbles, or if you don't have one then use the hose without a nozzle and rinse the car in "sheets", starting high on a panel and work down from there. Another method, after the main rinse at medium strength, is to buy a garden sprayer (i use a 3gal) and fill with distilled water. Final rinse with this and you will get no water spots (though drying is still preferred) and use about a gallon a car (80 cents or so a gallon)
Dry --
I use a waffle weave towel for drying in warm weather. It is efficient, and with my wash method it does not get dirty. Dont use a waffle weave if your car has been touchless washed. It will get filthy and you'll be sad. You can still wash waffle weave towels but they don't cycle as much as cotton or non-filled microfiber towels IMO. Otherwise, use 2 cotton towels. One to dry, and then one to redry. Panel by Panel. Drying is the most "lightbulb"(realization/cool) moment for some people -- When you aren't washing correctly your drying towel actually gets DIRTY! That is basically telling you that a. Your car is not clean b. You are dragging dirt around without any soap/lubricity and c. You would be best off NOT drying your car if this is the best wash you can perform (maybe on a trip at a wash bay) currently with the tools and/or time available.
Cold Weather --
In Cold weather, I do everything slightly different, and all in one set of steps most of the time. 25-50 degrees is not an unsafe time to wash your car in my opinion. Below 25 degrees, it is. I use 4 oz. of ONR with 4 Gallons of Warm (not hot) water in a 5 gallon bucket, and put that bucket inside a rubbermaid mop bucket with wheels(see pics). I then fill around the 5 gal bucket with clean water (rinse water). This way it has wheels to roll around the car, and I use 2 Microfiber towels and a cotton towel. One Microfiber wash, one rinse. Go panel by panel and wash the panel, then rinse it, then wring out the rinse towel and wipe the panel again, then use your cotton towel to final dry it. Stick this in your back pocket between uses. You're going panel by panel wash, rinse, and dry...
Windows --
Windows are tricky. It never seems like you can get them clean, but with some elbow grease (yes on windows) you can. First, the worst thing to use is Windex or any ammonia based cleaner on auto glass as has been discussed a bit and is MAINLY for the rubber surrounding the windows which is a long term thing, but also for window film and really, non-ammonia cleaners work better to avoid smudging. Keeping this in mind, the same concept as paint comes into play on windows. Get the "big stuff off," then polish(not in the traditional sense, if needed), then finish(not in the traditional sense, if needed).
First, clean the windows as normal with an appropriate cleaner and either a microfiber glass towel, or a paper towel. For cleaning solution Mother's now makes one and invisible glass is a staple here as well.
Second, To "polish"(i.e. remove water spots) them, you can use a clay bar esp. one designed for windows (Griot's Garage makes one) or use a NEW piece of paint bar. Else, you can use a window stripper made by permatex (available on amazon). This is the one area I haven't yet found a cheap solution that is safe to do. Invisible glass gets alot done, you might not need this step.
Finally, Finish with Rain-X (cheapest) or Aquapel (Best). And maintain with Rain-X wipes if you'd like fresh glass all the time. Aquapel is supposedly the best for results, but i've found that it's main benefit is how long it lasts for: months versus weeks.
Plastic -- I use Plexus to clean, protect, and finish all Plastics. I've use Sonus products to correct plastic items, but went through them and you can use fine grit sanding or polishing agents too, just take care, if applicable, to wipe clean right when done. Dry formula on plastic can leave discoloration. "Try in an inconspicuous/unimportant area first." Plexus is pretty impressive on lamps overall and makes those surfaces look impressive in a noticable fashion for a while.
Interior -- For the glass, an appropriate Cleaner (invisible glass for example) should be enough. No extra caution or steps needed.
For seats and carpets, this could really get lengthy so I will leave to you. Also, YMMV on many products out there so test on a hidden area, and keep in mind your own materials and their condition. Some products I will note: Mequiar's Carpet Foam, Lexol Leather Products, Plexus, Scotchgard for Auto's(be careful to have windows rolled down and the doors open. This is an "overspray"ish potential problem situation for windows), 303 aerospace products.
For vents and detail work, use Q-tips and canned air along with a fresh towel.
A Normal Car Wash:
Pre-Rinse --
Wash --
Rinse --
Dry --
Cold Weather --
Windows --
