It will crank with no problem or slowing down of the starter. but just wont start. It will take up to 4 or 5 tries or sometimes not at all until someone else tries. Once it starts it will purr like a kitten. drives fine no hesitation . Fuel pumps at 60 PSI. Alternator charges fine Batttery is brand new 2 cam shaft sensors from solinoed at 70.00 dollars each . they cleaned the MAFsensors with some kind of spray. Added half a little bottle of something when I suggested maybe is water in the gas tank. After 6 trips to mechanic he told me there was a crack in the manifold which is causing the problem. He said it would be 3000 dollars to fix at his shop. Sugggested I go to \midas they could weld it . I do not think there is a crack at all he tried to show me I couldn t see one. Does anyone know if a small crack would actually create this problem only on a cold engine?
And the OBD code reading was 172.
