Does anybody know the torque specs on a valve cover?
1 reading
14K views 2 replies 2 participants last post by  Joeey
From the '15 manual with torque sequence.
Note: Install a NEW gasket.
Note: Add 14mm bead of sealant part # 12378521 at right and left T-Joint where front cover meets head and at rear of camshaft cover right and left T-Joint where vacuum pump bolts on.
Camshaft Cover Gasket (1) » Install
2.
Camshaft Cover (4) » Install
  1. Camshaft Cover Bolt (3) » Loosely install [19x]
  2. Camshaft Cover Washer (2) » Install
  3. Note: Ensure the long camshaft cover bolts (1) are installed in the correct positions.
Camshaft Cover Bolt (1) » Loosely install [4x]
6.
Caution: Refer to
See: Service Precautions\Fastener Caution Fastener Caution.
Tighten the bolts in the sequence shown. 10 Nm (89 lb in) .
