1 - 10 of 10 Posts
does anyone know the type of bulb needed for the dome light? i cant find it in the manual and i want to change the bulb to an led bulb, i was thinkin about 194? is that correct? and is it the same for the two lights that you press and turn on?
Just did the dome and map lights even the two behind the dome for the rear passengers. I bought all my bulbs from Superbrightleds.com they have all you need.
The dome bulb and trunk is the festoon bulb and that part part number is 561. The map light bulbs are 194. Hope this helps.
Here are some pics of the map and dome with the rear passenger courtesy lights on
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
THANKS! That helps a bunch, and looks just how I want mine, except I only have the rear facing dome? Thanks for the part #s though, gonna check it out when I get home.
no problem glad i could help :) and you will love it once you get all the lights in :D just be gentle when removing the lens to change the bulbs, its pretty easy but don't pry on them too hard.
So, you got this http://www.superbrightleds.com/cat/festoon/filter/Cross_Reference_Number,RL4410,21,207: for the 561 bulb? Did you notice any loss of light distribution since this is a 120 degree angle bulb, or was that sufficient? And then you got this http://www.superbrightleds.com/more...194-led-bulb-15-smd-led-wedge-base-tower/910/ or something else? I used this bulb for my license plate bulb and it works nice but is a tight fit in the lamp. I was thinking of using this http://www.superbrightleds.com/more.../194-led-bulb-9-smd-led-wedge-base-tower/207/ for the rear side marker in red and I'd like to use it up front in yellow but will it take the heat of the headlamps over time? I've heard that it won't withstand the heat but I thought maybe technology overcame that. Any insight on this?
sorry for the long reply i've been very busy and since my BU was in the shop for a month (rear ended), will post on that topic soon.
To answer your questions i haven't noticed any loss of light distribution and for the map lights i used http://www.superbrightleds.com/more...led-bulb-5-smd-led-wide-angle-wedge-base/206/
I haven't got to do the exterior just yet but will do as soon as i get the time.
1 - 10 of 10 Posts
