DRL Issue after installing LED
3193 Views 2 Replies 3 Participants Last post by  campb292
I have a beautiful 2015 Malibu LTZ with the 2LZ Package. My driver's side DRL works very infrequently. so i just turn on my fog lamps. then they both work. I believe it is an issue with the Relay. Both DRLs used to work. I have installed LEDs Throughout the car. Any Advice? The fuses are fine.
Help me...Tim P.
Happy Malibu owner
it may be your LED bulbs that the car is having issues with...by the way, when you turn your Fogs on those aren't your DRLs working but your actual headlights (you can find this out if you check your taillights as they will be illuminated too)...your headlights (low beams) and DRLs occupy the same location...unless the 2015 is mechanically different than the 2013...
good luck with your Malibu
Reactions: 1
Closed in favor of newer discussion that contains more info.
