1 - 18 of 18 Posts
I have a 2010 1LT Malibu and I have noticed that the car is equipped with daytime running lights, I think this is a novel idea but I was wondering if it is possible and if so how to switch the DRL duty from the low beams to the high beams like the Toyota/Lexus/Honda/Acura vehicles have, the reason I want to do this is because I want to prolong the life of my HID low beams by not having them on all the time and divert that task to the high beams because I never use them. Currently I have disabled the drl's by pulling the fuse but I want to reinstate them as the high beams because I like the look of it an the idea of having daytime running lights. So is it possible to divert the drl duty from the low beams to the high beams and if so how?
Thanks
· CMF Veteran Member
I seem to remember DrivenDaily saying he had rewired his DRL circuit on his old Malibu to power the front parking lamps. It shouldn't be that big a deal to do the high beam lamps the same way. The trick would be to reduce the brightness. The usual method is to power the lamps in series to divide the voltage drop across each lamp in half. If he happens to miss this thread, you may want to ping him.
Thanks
SS is right. I modded my '09 so the turn filaments were DRLs instead of the low beams.
But something I discovered since getting my '11 is a correction of a statement I made back then. I said that the low beams are at full 12V during DRL operation and are merely kept on by a separate relay. Since I modded the '09 rather early in its ownership I never paid attention, but with my '11 I've noticed that when I purposely switch from DRLs to headlights the low beams get brighter. That means that somewhere, somehow, the DRLs have reduced power. I don't see anything at all on the schematic that tells me how they do it. It's possible that it's just the undersized wiring that limits the voltage, but there aren't any resistors or fusible links identified anywhere in the DRL circuitry.
If you follow the link below you'll be able to download the schematics to the 2008 models. For '09+ they discontinued the fender-mounted turn signal repeaters, but other than that I never found anything different in my '09. For '10 they moved the location of the mirror adjuster and locks. The mirror adjuster for '08 and '09 had a selection switch that selected either left or right. For '10+ it has an additional center "Off" position. For '11 the paddle shifters were removed from the steering wheel and replaced with a single button on the shifter.
http://dl.dropbox.com/u/4191695/08_chevy_malibu_complete.pdf
Look on figure 49 for headlights. At the top left is the DRL fuse and relay. There's a purple line going from the NO contact to the NO contact on the low beam relay. The actual wire is under the fuse block in the engine bay. To access it you'll need to disconnect the battery wire feeding it, and the bolts in the center of the block. Then you'll have to wrestle a little with all the snaps they use to keep that plastic stuff together. But underneath is the purple wire you need. I actually removed my battery to make it easier to work on it.
Like SS says, I would favor having you put the two high beams in series to reduce the power output. Otherwise you're gonna be blinding people as you drive. You could also see about getting a huge resistor, like maybe the kind they used to use on Chrysler vehicles back when they had external resistors on the coils. It is designed to be bolted down and carry some current but I don't know if the high beams are too much. It might require one per lamp.
A number of studies have discovered that amber-colored light is easier to see during daylight hours than white light. My preference would be to see you switch over to the turn filaments like I did, and like I'm gonna do on this car. It's a fairly simple circuit and doesn't endanger any expensive halogen bulbs. I designed it myself and it worked flawlessly until I removed it to trade it in. The only reason for holding off installing it on this one is because I want to place it in a different location since it sometimes interfered with putting the battery cover back on. (It was between the fuse block and the fender, but under the battery cover.) Heck, I'm even thinking about relocating my battery to the back of the car just to gain some room and a slightly better weight distribution, but that'll wait until better weather, and until or if I decide to do it. Anyhow, I'd be happy to share my circuit with you. If you'd like, I'll even build it and ship it to you for just the cost of doing it. (For all other readers: This offer is for King Air only.) The short intro to the parts: DPDT relay, 2 diodes, and 2200mF capacitor. The rest is wiring.
I thought this was gonna be a short post, but I seem to have written a lot! Sorry for the long read.
Wow thanks!!! I do agree with using the turn signal filliments instead of the high beams now that you mention it, and I have also noticed the greater contrast from the concrete to the lights when they are amber instead of white, so basically, I just have to find the purple wire coming from the fuse box and rewire to tap into the turn signals on the front, and then use your (DrivenDaily) circuit to maintain the functionality of the turn signals and parking lights? As you can tell I have little experiance in electrical work, so please excuse my lack of knowledge when it comes to the subject. Haha.
Thanks
OK, stand by for a circuit drawing...
Standing by... Haha
And here are the steps to find the purple wire that turns the low beams on.
This is a link to the entire album of 19 images, in order of what steps to take as seen below:
http://s180.photobucket.com/albums/x173/fell-uh/2011 Malibu LTZ/DRL/
Step 1. Using 10 mm remove GROUND cable from battery terminal. Move to side, then remove POSITIVE cable and feed to fuse block (with 7 mm).
Step 2. Using 13 mm remove battery clamp
View of fuse box from passenger side
Step 3. Using the screwdrivers as a guide, pry at these points to release this side of the fuse box
Step 4. Lift this side of fuse box to this level (screwdriver being used to hold it for the picture)
Step 5. Lift the unlatched side and move toward passenger side. This is what it will look like from the driver side
Step 6. Using 7 mm unscrew 4 "bolts" in center of fuse block until they spin freely. They don't come out. Then release bottom cover by unsnapping it.
Step 7. Separate halves
Step 8. Snap connectors out. You may need to pry them a little, but they DO snap out.
Step 9. Remove cover from second connector (counting from left in previous image). Find where a purple wire is connected to the same terminal as a slightly larger tan/white wire.
Step 10. Cut the purple wire identified in step 9
Step 11. Add terminals (notice male & female, and which wire they're on) so you can restore the DRLs to factory function in the future (optional). Mine are the crimp kind with the insulator removed and then soldered. It's a much better conneciton.
Step 12. Insulate the terminal with a heat shrink wrap, or tape it carefully.
Step 13. Heat shrink after heating
Step 14. Cover "orphan" wire with heat shrink or tape to prevent shorting during low beam operation.
Step 15. Attach a terminal to a LONG piece of STRANDED wire (mine was 4 feet long - it's cheap enough!), then cover with correct size heat shrink, then add a larger heat shrink to cover entire terminal once it has been plugged in.
Step 16. Use a wire tie or add a loom cover (shown), then reattach rear cover to connector.
Step 17. Reinstall connectors to bottom of fuse block. Install #2 then #1, then install #3 then #4.
Step 18. Reinstall fuse block into vehicle by snapping it in. Insert on driver side first, then snap in the passenger side. Keep new wire accessible.
Step 19. Reinstall battery, battery hold-down clamp, POSITIVE terminal and fuse block feed, then NEGATIVE cable.
Discussion Starter · #13 ·
Wow thanks!! Thanks for devoting your time to creating such a great write up! I really appreciate it!! So after I create the extension of the drl wire like you did I use it in your last step I wire it to your circuit "creation" and then connect all the wires coming off your module to the turn signal and parking light wires, correct? I apologize for my lack of knowledge on the topic and appreciate your time and effort on helping me understand.
You're welcome, and you're close on what to hook up. The parking lights are not part of this DRL mod. We'll be using only the turn signals.
If you look at the drawing you'll see where there are 4 notes where a wire will need to be cut. (There are 2 wires to cut, resulting in 4 ends that need connections.) You have two options here:
1. Find the wires under the hood and do all the mods there, or
2. Route the new wire into the cabin and do the mods there, at the BCM under the front right console.
I did mine in the '09 under the hood. I'm going to do mine at the BCM this time. It'll keep the components out of the weather and the under-hood temps. Plus it'll be completely hidden under the console.
At either location you're looking for a dark blue/white wire and a light blue/white wire. Light is left, dark is right. When you find them and verify that they are the wires for the turn signals, cut each one, but do so in a way that leaves you enough room to work on them. Then turn on the hazard flashers and, with a test light, determine which end is flashing and which is not. For each color there will be one flashing and one that isn't. The flashing ones are the ones coming from the turn signal switch. Refer to my drawing and hook the light one to the one that says "Left turn signal from switch" and the dark one to the one that says "Right turn signal from switch". Now hook the remaining light one to the one that says "Left turn filament to bulb" and the remaining dark one to the one that says "Right turn filament to bulb". Now all you have to hook up is the new wire from the original DRLs to the one that says "+12V from DRL wire" and the remaining wire (on the DRL device) goes to ground.
Test the operation. If done correctly, when the key is on and the gear selector is not in P, the DRLs will turn on. You will see the "turn signals" illuminate but they won't be flashing. When you operate either turn signal, both DRLs will cancel and the turn signal will flash. When the signal is turned off the DRLs will resume after about a second.
Discussion Starter · #15 ·
Great thanks for the write up! So just to verify, there is a dark blue and light blue wire at each turn signal bulb that I can access from the wire harness that powers the entire headlight assembly (on that side) and then cut both of those wires and connect then repeat the cutting and connecting of the dark and light blue wires on the other turn signal wire harness assembly on the other side of the car
Almost.
When you take a wire that is whole and cut it you end up with two ends. So, cutting two wires gives you four ends. Those are the ends you attach to the device in my drawing. If you (King Air Pilot) would like me to build one and send it to you, PM me and we'll work out the details.
The left side has a light blue with white stripe. It gets cut. The cut end that goes to the bulb goes to the one in the drawing marked as such. The cut end that comes from the turn signal switch goes to the one in the drawing marked as such.
The right side has a dark blue with white stripe. It gets cut. The cut end that goes to the bulb goes to the one in the drawing marked as such. The cut end that comes from the turn signal switch goes to the one in the drawing marked as such.
Discussion Starter · #17 ·
Thank you for being patient with me and explaining it so simply, I apologize if I made you frustrated with my "slowness" when it comes to electrical work, but I fully understand what you mean now, I will pm prob on Monday because I am interested in purchasing one of your DRL circuitry devices. Thank you for all of your time and patience, I will pm you on Monday to work out the details.
Hey, we all have to start somewhere! When I was 18 I was stripping wires with my front teeth so much that I actually developed a little groove! Thankfully it grew back out after I started using tools instead. I also just twisted and taped my splices but now I solder and heat shrink all of them.
I'll put together a parts list and go shopping, assemble it as a kit, and make it so that all you'll have to do is find the wires and hook them up.
We'll make our arrangements via PM.
1 - 18 of 18 Posts
