Hello I own a 09 Malibu and recently went to wash car and I got home I noticed a burnt plastic smell from my engine and noticed fuse box burnt and fuses melted! Is this replaceable ? How much ?Is it possible to do it myself or should I let an expert do it. And what advice do you have for me
Check out a junkyard and see if there are any there for less money.
It can be done by a DIYer, depending on your talents.
I drive a 2012 chevy malibu out of no were I'm come to a complete stop and I get a engine reduce power follow by service esc and traction control and the scanner keeps giving me the same code knock sensor and the peddle I replaced both and still the same problem it happens after I drive it for about 1hr
I also had the ecm replaced cause they told me that might be the problem
Thank you
You both might benefit by reading the thread below:
