I'm trying to remove my flex pipe on my exhaust. I loosened up the input bolts on the input flange but i can't on the output flange. Does anyone know how to take these off?
Light Automotive tire Gas Automotive wheel system Cylinder
Lots of PB Blaster or Kroil, wait a day, the lots more.
If that doesn't loosen 'em, then it's time for Mr. Sawzall.
Thanks, the only problem is its like a carriage bolt on the other side and if i cut it how will i get the pieces out of the holes after cutting them?
That's a cut them off and drill out the holes on the convertor side so you can use bolts to reconnect them. New gasket needed also.
I don't see any sign of the nuts there were on those studs. I used a ox-acetylene torch on my daughter's Spark to heat the nuts (they were still there but frozen with rust) till they were red hot. They came off easily that way. I don't think there's enough left to work with on yours. The sawzall drilling out what's left is probably the quickest way fix this. Good luck with your repair.
