I pulled the engine codes if they help
PO57D
PO463
PO453
PO69E
PO57D
PO463
PO453
PO69E
Sorry for late reply! Is this what you’re needing? These are the current codes I just pulled, I have photos of the obd2 scanner too if those would be more helpEngine-codes.com is a good resource.
You need the U codes to be read also, those are communication failure codes that indicate issues in the onboard data stream and help with diagnosis.
A 4 code families need to be read not just the P codes.
No, he asked for the U codes, which are stored differently. You are posting P codes.Sorry for late reply! Is this what you’re needing?
Could these be what you're referring to? sorry no one has ever asked about any other codes so I'm learning how to get the other codes.No, he asked for the U codes, which are stored differently. You are posting P codes.
