I have an ongoing issue with my 2016 Malibu 1.5L Turbo. I will be driving normally then all of a sudden the RPM’s shoot to around 5k, the check engine light comes on and the car gets stuck in 2nd gear. When it does finally shift, the car shifts so hard that I practically get whiplash. When I try to speed up, the rpm’s go up then back down and the car begins to stutter. When coming to a full stop, the auto-stop no longer works and it takes between 10-15 seconds to get to 10mph. If I turn the car off then back on, the issue happens again approximately 2 minutes later.
I’ve taken it to the dealer 4 times and on 2 occasions, the issue is miraculously gone and it doesnt happen again for about 1,000 miles. It happens randomly; on the highway, back roads and once in the city.
The dealer replaced the TCM and a few other parts (I know everyone needs this info but I forget the other parts) and that cleared the issue for about a month. Then I fully broke down and was barely able to make it over a hill; I had to have it towed because it was not recognizing what gear i was in. When I tried to put it in reverse, the whole car moved back and forth 3 times before going into reverse, but again, it wasn’t showing I was in reverse on the dash.
After finally shifting in and out of the gears, I finally got it to recognize it was in park for a second then turned the car off for 45 minutes. I turned it back on when the tow truck arrived; the check engine light was on but it shifted and recognized it was in drive and reverse.
Dealer drove it 30 miles on 2 separate occasions and the issue was not present but check engine was on so they cleared the codes and sent me on my way.
Do I have a lemon?
Attached are the codes being thrown.
Do I have a lemon?
