Hello everyone! I have a 2010 chevy Malibu lt with the 2.4 engine. It wasn’t marking the coolant temp sensor on the gauge so I replaced the coolant temp sensor. When I replaced it, it worked for a couple of days and started doing the same thing. I went and bought another one thinking it was a faulty part and replaced that same sensor again. It worked another two days and it went back to not reading the coolant temp. I was under the hood one day and I pulled the negative battery cable off the battery to reset everything and the coolant temp sensor was working again. I drove it another couple of days and the coolant temp sensor wasn’t reading again. The coolant temp sensor only works when I pull the negative terminal to reset everything. It will work for a day or two and then quit reading the temp again. I’m thinking about replacing the negative battery cable. Anyone know what it could be???
