working on a 2020 Malibu LT with the 1.5 turbo.
heres the situation, vacuum pump seized, took out the exhaust cam with it,
tore engine down, replaced exhaust cam, timing chain, guides, and tensioner.
reassembled, car didnt want to start right away, had to crank many times, now fires right up after battery is unhooked and reconnected, will idle perfect for a minute or so, then throw an engine light and reduced power message, then starts to stumble and will die without throttle.
codes im getting are
P0011 - Intake camshaft over advanced
P0016 - crank - cam position correlation
i double checked the colored links were on the timing marks before i released the tensioner.
not sure where to go now...
any advice?
any advice?
