21 - 40 of 66 Posts
Yeah I’ve been driving around in 7 and it doesn’t cut the car off when i stop. But is there always around the start to stop messing with the power to my amp? When the auto stop turns the car off the amp still works fine but when it starts back up to go it cuts it off for about 5 seconds and it’s annoying haha
Yeah I’️ve been driving around in 7 and it doesn’️t cut the car off when i stop. But is there always around the start to stop messing with the power to my amp? When the auto stop turns the car off the amp still works fine but when it starts back up to go it cuts it off for about 5 seconds and it’️s annoying haha
I installed an ultra capacitor Bank in the back right next to the amp and it solved the amp shutting off on startup except for the coldest days.
A couple days late to the party but give these guys a call. They do custom harnesses and include the Malibu in with their harnesses.
lljcustoms . com
put it together in your browser. My post count isn't high enough to post links
I know I'm late to the party but just adding some info from my install yesterday.
I didn't bother with line out converters. I grabbed a good set of RCA's, snipped them, attached to the pre-amp'd speaker wires(The smaller wires), then ran directly into my aftermarket amp. I then ran speaker wire out of my aftermarket amp back to the stock speaker wire that would normally come from the chevy amp.
In other words, I just bypassed the stock amp completely and tucked it all in that nice cubby.
Why? Well, I replaced the door speakers too. Also...RCA pass through on the aftermarket 4 channel amp. (Rockford Fosgate R400-4d). So now I have regular RCA's to run out to whatever I want. In my case its a under seat sub. In someone else? 2 15's. Or whatever else they want.
My way isn't better. Just another data point on this awesome thread.
Hey, I was told that the speaker wire coming from head unit are low level inputs and that we can bypass the stock amp to an aftermarket amp. So since you did that, you have no issues right? I thought the Bluetooth and chimes are powered from the stock amp? That's why I didn't have it bypassed in my ex 2016 (now I have a 2020).
So all you did is disconnect the speaker wires from stock amp and connected to your aftermarket amp and everything works from the head unit? I'm pretty sure your quality is clean as going thru the stock amp into an aftermarket amp causes distortion even with a processor like I had in my 16.....
EDIT FROM ORIGINAL POST. The Rockford Fosgate R400-4d I had initially installed was not rated for 12v input through RCA and had overload shutoff issues. See below for my current setup.
Correct. Utilizing the speaker wire directly from the head unit that goes into the amp and converting that to RCA (I simply cut RCA cables, crimped and heat shrunk, but do as you wish), you can run that directly into an amp. As long as the amp you are running to supports up to 12v input sensitivity. This is very important as many lower end amps will not accept 12v RCA in. I have the https://rockfordfosgate.com/products/details/p600x4/.
Then simply utilize the stock speaker wire for the output as well. You will of course need to cut and extend to reach your amp that I imagine you will put behind the trunk wheel well. (Plenty of room on both passenger and driver side)
If you try to do this with an amp that only supports say... 8v input sensitivity, you will have overload issues and you amp will shut off(I know because I went cheap initially with one that only supported 8v input). You can fix this by running line out converters, but by the time you factor those in cost, tune, and time wise, just pay a little extra for the amp.
It's crystal clear, no distortion or feedback of any kind. My stock amp just sits there unplugged. The only thing I "lose" is the ambient noise microphones that GM has dealers unhook anyway because of the low RPM feedback loop.
The hardest part is just making sure you don't mix up the speaker channels.
Oh, I disconnected my A Pillar tweeters as they became heavily overpowered(too loud). One day I may do something about that. Maybe it was just a tuning issue on my end. Basically the 4 full range speakers I installed sound so great I haven't cared. Someone else may care and maybe you should run a crossover or something from your front door speaker to the A-Pillar tweeters. But I'm happy as is.
Thank you!
How do I disable the active noise cancellation in my 2018 chevy malibu? I have encountered this problem when I installed my sub and amp correctly and it sounds terrible because of the active noise cancellation.
There's are purple wire on the top harness connected to the factory amp snip it and tape the ends
While it may be an "easy" fix, please don't cut wires if you don't have to. Call the folks I mentioned above (Car Audio - LLJ Customs Car Audio Fabrication L.L.C) and ask them about an ANC Bypass. It'll cost possibly less than $20 and can be removed and installed as you please without cutting things.
So just finished my install and it was the biggest pain ever. For those with the 2018 bose system you have to ignore 99% of this post. First of all the 2017 and 2018 are totally different. The 2018 with the bose has no remote wire going into the amp. You can get it from back the head unit but if you are like me and didn't want to touch the head unit you won't find a remote wire going into the amp. It uses dada signals. So you must use a LOC that has a remote signal built into it. That will control the signal off and on. Also for my model there isn't simply 1 wire to cut for the auto noise cancellation. There are 3 microphones with 2 wires each. The harness that controls this has 8 wires. 6 for the ANC and 2 others from what I can tell control the turn signal chime and the parking assist. Good news is there is a harness you can buy on Amazon for $25 bucks that actually works. It just connects the 2 wires leaving the 6 microphones off its 1000% worth the money. I called best buy, Crutchfield and my Chevy dealer and nobody had answers for me so i had to figure all this out on my own.
Can you provide a link to that specific harness and can you post pictures of your install setup or explain how to wire up the loc
So like the title says I have a 2018 Malibu LT
And I have no idea how to go about wiring a LOC to install an aftermarket amp for two subs I want to install in the trunk
I’ve read a few different ways and I’ve installed one on a 08’ Altima before but seeing as there are no rear deck speakers I’m kind of lost any help would be greatly appreciated
Heres what i did on my 2015 malibu wich had no rear deck speakers ... I tapped into the left door speakers made a speaker wire to rca connection i used the battery in the trunk to run my ground an power to amp i didnt wana hack into the harness for the remote wire so i ran a wire from the battery on amp to the remote on amp.... If u run yours like that i would remove the remote wire from ur amp so it doesnt constantly stay on.. I tapped into the right rear door speakers as well but found out that the left side beated harder so i got a one rca into 2 rca adapter an i got a 1000 watt alpine mono amp an 2 15 inch subs
I ran my system without a l.o.c
Yeah sure i will help any way i can. The way i ran my power wire was up the passenger side and tucked it in the door sills. Theres a grommet under the dash behind the glove box i ran through. Then to hide it in the engine bay theres protective carpet on the firewall u can tuck it behind. I hooked up to the battery. Now in the back my power went under the back seat cushion and beside the side airbag, and into the trunk. We are pretty lucky here because everything else we need is right there behind the panel on the passenger side. Pull that panel and ur factory amp is bolted right there. Theres also a nice little cubby there for an amp and a loc, (line output converter). There are 3 plugs in ur factory amp one is for power input which is where i got my remote power for my aftermarket amp. The center plug is ur speaker input, this is where u wire in ur loc. If u have ever installed a system before it just doesn't get any easier than this Malibu. Oh one more thing i had to do and it didnt start for a few days and that is active noise cancellation, ive seen a few people just cut the wire which is purple i beleive, myself i just unplugged it and its been a couple weeks and those kicker 15s are still poundin loud and clear. I hope this helps.
My coworker is good with car audio and we ended up with no sound from the speakers at all. We unwired the line output converter and went back to stock. Did we trigger the radio anti-theft system because we didn't disconnect the battery before tapping into speaker wires? I have a 2018 Chevy Malibu 1LT with 8 inch touchscreen without bose. PLEASE HELP!
i could use some help and really appreciate a response asap, i just bought a 2020 malibu and wanted to go with a whole new subwoofer setup, i laid out all my wires, wired the loc how i thought was correct and when i put the car in acc or even started it i don’t even get power to the amp
Good day. Lots of questions that you didn’t cover. “Laid or all my wires”, “wired the loc...”, etc.
Can you be more specific on those points as well as given some more info to the following. Where did you feed power to to LOC? What LOC? Are you bypassing the factory amp? What new amp are you using? Did you cut wires to do any of this? How are you routing sound back to the factory speakers? Pictures would help as well. Please be as specific as possible so help can be given.
Thanks!
i would love to give as much info as i can, just wanted to get myself out there. amp is a skar rp-1200.1D, with a skar 12” sub. loc is by metra, i’ve only done one other system with an loc before and it wasn’t for subs just marine speakers in a jeep, went very smooth. i’ll take some pictures of the loc and where i’m tapping in. i planned on just wiring it into the factory amp because i have no rear pkg panel speakers, i grounded the loc with the battery and rabbits 12v to a cigarette lighter in the backseat, if you have any suggestions on how it would be easier with bypassing the amp all together or anything to help that would be nice, also no i have no cut any factory wires at all, plan was to just tap the door speakers with the loc and give it power and then run the rca back to the amp, my problem right now is that i may have chosen a bad ground for the amp it’s self as i’m getting no power indicator on it at all, first i grounded with a self tapper under the carpet of the trunk and now it’s on a seat mounting bolt
black wire
Thanks!
this is the loc, black is grounded at the battery, green is going to 12v via cigarette lighter, blue is remote running back to the amp, and then the two wires that are going up to the amp are tapping the door speakers for signal, i figured it would be easier to get signal from the factory amp because these factory radios have no speaker wires to them
Thanks!
this is the cigarette lighter i used to get 12v power to the loc, not a secure splice or anything just temporary to try and get everything powered before i put everything back together
21 - 40 of 66 Posts
