Oil change on a 2008 Malibu 3.6 v6
Tools:
15mm wrench
10mm socket
Flat head screw driver
Oil filter wrench/pliers
jack and stands/ramps (I used ramps)
Oil:
5.5 quarts
Filter numbers:
A/C Delco PF48
Mobile 1 M1113
Draining Oil:
Under the car on the passenger side you'll find the oil plug on the back side of the oil pan. Use the 15mm wrench.
Oil filter:
Under the hood remove the intake tube that runs from the airbox (on the passenger side) to the intake on the drivers side. To remove the tube you need to loosen the clamps on either end of the tube (using screw driver). Next unplug the PCV valve on the driver side on the tube.Then remove the bolt holding it on the driver side just above the radiator using the 10mm socket. After the tube is removed the filter is much more accessible then from underneath and not near as messy. Also since the filter is screwed on at an angle you can't pre-fill it with oil. I oiled the O-ring and put about 1/4 the oil filter capacity and put it on hand tight.
Tools:
15mm wrench
10mm socket
Oil:
5.5 quarts
Filter numbers:
A/C Delco PF48
Mobile 1 M1113
Draining Oil:
Oil filter:
