Read this thread beginning to end and someone came close but didn't solve the problem I have. Back in the 60's I did a lot of light engine work (no rebuilds) and in the 70's a lot of VW work. I include that info in that I have some experience but not much since the dreaded computerization of the automobile, thus my user name.
I'm trying to replace the intake and exhaust solenoids. The problem are those blasted electrical connectors.
My Plan Beginning This Morning
1. Unhook negative term of battery
2. Unhook air cleaner hoses
3. Remove oil cap & replace w/ towel
4. Remove engine cover
5. Replace the 2 parts which involves un- screwing and re-screwing
6. Reverse steps 1-4
I saw a girl on utube do it in 15 minutes.
I figured if SHE can do it in 15, I should be able to do it in 60 minutes.
Well...
1. I've always seen negative cable clamps very similar to the positive cable clamp. Nope!! This puppy was like a washer that slipped over the terminal. O.K., I consider myself pretty flexible in my thinking. But now I'm facing a North Korean nut that's between either 8mm and 10 mm or 5/16 and 7/16.
So she was done with the whole project in 15 minutes... I got the battery disconnected in not much more than 15 minutes.
2. Her hose connections were not that much easier than mine.
3. I was faster than the girl removing the oil cap because I didn't have to explain what I was doing and why.
4. Her engine cover had 3 screws right on top so access wasn't even a consideration. I had only 1 screw and 3 pop-in (or pop-out)snaps. For the 1 screw I had to deal with, I needed a 12" screwdriver, a flashlight and now, physical flexibility.
So...3 hours later, (did I mention I have COPD and we’re surrounded by wildfires?)
5. Now I am at the meat of the matter...
What I need is a video with slo-mo and written notes explaining how on earth
one gets those fracking, electrical connectors to the Camshaft Solenoids
disconnected.
After all that I hope I posted correctly.
