Ok, this is a breeze so here we go...The part # is 19212052 and I got mine from www.gmpartsdirect.com for $123.45 shipped.
I did all of this in about an hour and that included taking pics! This is what I started with....
When you get them you will get four (4) handles and four (4) caps, (one with the key-hole for the drivers door) and aside from the key-hole cap it doesn't matter which one goes on which door.
All you need for this is a T25 Torx screwdriver (I also used some rags to clean behind the old handles and then put on some wax to protect it).
Step 1.
Open the door and look level to the handle on the inside of the door and you will see a round rubber plug about the size of a dime. Remove that to get to the torx bolt. I was able to remove the plug by hand but if you can't, use a flat plastic blade to pop it out.
Step 2.
Loosen the torx bolt until the cap is loose but DO NOT REMOVE IT THE BOLT ALL THE WAY. Once it is backed out a good bit, pull the handle out and remove the cap.
Step 3.
Grab the handle and pull it toward the rear of the car and it will pop free and you can pull it outward from the car to remove it.
Step 1.
Step 2.
Step 3.
