when you have the key in the ignition and turn the car the key fob makes a noise rubbing the dash only have 1 key and the fob in it. the rubbing noise is annoying. can't think of a way to keep it from rubbing. any ideas
As far as I know they all have it. It is a area below the key with a line around it. If you push it, it is soft.i have 2009 malibu LS and theres no rubber area i guess they left that off the base model maybe i will see if the dealer/parts dept. sells that built- rubber area for mine thanks
