1 - 7 of 7 Posts
Hi all .. first of all it's a pleasure to join this site and share with u the good stuffs
i'm actually looking for LED daytime running light for my car ..
i have 2LT malibu .. can anyone helps me plz .. if u found what i want in the online stores like e-bay or amazon i'll be happy ..
thanx indeed :)
@ someone1221
What year is your car? You have it listed as "1991".
hello all .. sorry i made a mistake about my car's year .. it's 2010 and i wrote 1991 cuz i expected it's about my age :p .. i'm new in this site so i don't know what's the suitable section to post my order .. thanx all again and i hope to see answers ..
best regards
No problem. We just need to know how best to help you. Please go to your User CP and change your avatar so it says 2010. While you're there you also have the option to make a signature, and if you want you can include a picture.
· Banned
Re: i'm tired of searching .. help plz :( (DRLs)
....and your DRL is your low-beams so you can't use LED's.
Am i correct to assume that on my 2009 that my low beam headlights serve as my DRL? For some dumb reason always thought the day time running lamps were not part of the hi/lo beam system and that DRL were separate lights/bulbs. If i understand your post correctly i will most definitely pull fuse #46 to extend the life of my headlights....don't want the "bumper hazzle".
Yep!
When I had my '09 I thought they were running at full brightness, but shortly after getting it I converted my DRLs over so they ran on the turn signal filaments.
Now that I have my '11 I've discovered that they do, indeed, run at slightly reduced brightness, but they still use the low beam bulbs.
1 - 7 of 7 Posts
