Hello All
I have a 2017 Malibu 7" touch screen.
I am looking for information if anyone has it about the rear mounted amplifier.
About a month ago, i installed a LOC and an amp. it has been working great, until yesterday i got into the car and noticed the sub was hardly playing. I tapped into the 'amplified lines' (the thicker ones) when wiring the LOC. It is my understanding that the thinner wires are the signal from the headunit, and the thicker ones are the amplified signal going back to the speakers.
I am relatively skilled with a multimeter, so i began checking things, starting with the output to the amp. I started with a 50hz test tone, which i used to set the gains initially. Only 5v output to the sub (equivalent to 25w). I had initially set it up for about 700w RMS, so should have been in the neighborhood of 26.5v
Then i checked the voltage of the RCA's to the amplifier, and had around .300v. This seemed low to me.
I checked the input voltage to the Line out converter, and get 2.00V, with a 50hz test tone at 47 volume.
Now the interesting part is when i check the inputs from the head unit into the amplifier, i get the same voltage as the output voltage from the amplifier to the speakers....
IE, the front right speaker positive and negative are 2.0v from the head unit, and are also 2.0v going to the speakers after the signal has gone through the amp. This is equivalent to about 5 watts, so it seems like the amplifier is not amplifying anything.
Does anyone know the estimated output power of the amplifier? I have read it is around 22 watts or maybe 30 watts.
If anyone with a multimeter would be able to check the voltages their car puts out, that would be great. Its pretty easy to backprobe the green connector and get measurements
Any help is greatly appreciated!!
