Got an 11 Malibu LS...wanting to put aftermarket double din head unit with bluetooth in but need to make sure i buy the correct harness. Been told i might need to buy an interface as well as the harness. Anyone have any experience with this and know what direction to send me??
Crutchfield site is a good resource.
Hacking in aftermarket stuff should be done by a experienced shop or person VERY knowledgeable in automotive.
Even then be prepared for issues and compromises.
Reactions: afrock
You'll need a harness to connect to the factory wiring. And you'll need to do a bit of research to get one the keeps your door chimes and turn signal clicks. If you want to keep your steering wheel controls for the stereo you'll need an interface for that. It's complicated but doable. Crutchfield is definitely a good place to get the info.
