Same problem here. AC drain was not plugged but water was running back along the hose into the cabin. You will find LOTS of water under your carpet, both front & rear. Make sure you dry it completely.The padding is like "Shamwow", it holds an unreal amount of water. My dealer added a length of hose to extend out & down, so water can't run back into the cabin. Looks like a design issue to me.
I have an LTZ wit that problem where water comes in the passenger side door underneath whenever it rains. Does it happen when it rains or when you use your AC?
My guess is that when I hadwork done to replace speakers with better ones they screwed up the moldings and now water gets in when it rains. Ive looked it over and cant figure out the exact spot were it is leaking.
