I have a 2008 Malibu. The electric door locks only work when the car is shifted from park to drive or from drive to park. They will not work with the lock buttons on either door. Any suggestions? I have checked all connections and fuses
I’m starting to have this problem as well, where as the interior buttons not the remote allows for all door to lock and or unlock
In both instances, the switch(es) on the doors need serviced or there may be a broken or damaged wire. If any water has gotten into the switch(es), that alone could cause this to happen.
Remove the switch(es), carefully disassemble, service, reassemble, test.
