They will work just fine. It just might shorten there life a little. When I add my springs I do not plan on changing them.Will factory shocks work with the lowering springs you mention or should those be replaced too?
I'd stick with Eibach or H&R. A shop should charge about an hour and a half labor. Plus remember you will need an alignment afterwards too.this is one of the first things i plan to do to my malibu. does anybody have an idea what a shop might charge to install some lowering springs? i see on ebay some are cheaper than others; should i stick with eibach?
I get a little odor for the first few minutes I run the A/C too sometimes. Running the vent before and after seems to help. I have heard that it can be the wiper blades (they tend to give off an odor) since they sit right above the air intake. Some have sprayed Lysol into the air intake while the A/C is on to help this too.Silver, yesterday in NYC it was 90 Degrees so I ran the AC , it ran great. This am when I got in the car I had the regular outside air on and I had this foul odor coming from the vents. I switched the air to interior /or recycled air and smell went away . Did you ever have this ? Also I noticed when I put the recycled / inside air only on it feel like the AC is on when its not ... Your thoughts are appreciated.
I tried Lysol too but the odor would come back again after a day or two.I get a little odor for the first few minutes I run the A/C too sometimes. Running the vent before and after seems to help. I have heard that it can be the wiper blades (they tend to give off an odor) since they sit right above the air intake. Some have sprayed Lysol into the air intake while the A/C is on to help this too.
Anyone else have some input?
