1 - 8 of 8 Posts
The reason I'm posting this in the General Discussion section is because the problem no longer exists and hopefully it doesn't come back. I've fallen victim to the "service esc, service pwr steering, service traction" yadda yadda yadda. Scary experience because I was on a busy highway going about 60mph and the car completely shut down, lost power steering and braking, all that good stuff. Turned the key after I pulled over and it started back up after a few attempts. Called the dealership and brought it in the next day (yesterday). They had the car all day and they may have figured out what was wrong. They said the throttle body, the traction control module, the torque sensor, the anti-theft system, the MAF sensor, the ignition switch and the spark plugs (which were supposedly corroded) were all no good and needed to be replaced. They also suggested that my air filter isn't what should be used for my car and replaced it with an AC Delco filter. I originally had a Fram. I'm glad I got the extended warranty because I didn't have to pay a dime and my $199.99 diagnostic fee was waived. Not exactly sure if this is the cause of the problem but hopefully this won't return. I was a little less than pleased with all this, however I have good faith that this problem won't come back. I'm surprised that Chevy hasn't issued a recall for this problem considering how many TSB's I've read.
I've also had all aftermarket parts removed before this incident occurred. No HIDs, no LEDs, all bone stock. :(
I found this while working on my 2010 Malibu. The car had multiple issues with the electrical system, they were all intermittent problems turning on various service lights, inoperative cruise control and other things would happen when I would drive the car. The main fuse box under the hood had several steaks and blotches of corrosion on it. You have to remove the fuse box from the car. Take several pictures of the fuse and relay layout. Carefully remove and layout the fuses and relays, so you can put them back. If you look at the terminal side of some of the relays, you'll probably see corrosion on them, clean that off. Knock the bolts out that hold the wiring connectors on. Smash the tapered side of the square headed inserts that hold the block together. Remove the inserts and gently pry the block apart. There, you will likely see the green corrosion that is causing your electrical gremlins. Clean it off with some battery terminal cleaner and a wire brush. Brush on the terminal ends to clean them as well. I sprayed everything with non-conductive Corrosion X, (a great product). Put it back together, the inserts are okay to re-use. I hope this will solve many peoples problems. This part should be recalled, but I'm sure it wont.
Corrosion on electrical contacts is a well known issue with these cars, and folks have reported some wild issues which ended up being corrosion. I'm thinking Anna's car was fixed more as a side effect than a direct fix. Since you didn't have to pay, its all good, but they scammed the sh*t out of whoever covers that warranty. They just replaced everything they thought they could get away with and get paid for. Hopefully it doesn't come back anytime soon and the car has some new parts out of the deal.
Dealership.
Is the dealer that you take your car to, Manfredi?
Absolutely 100% agree! Don't ever go to that dealer for non-warranty repairs. They either have no idea what they're doing, or they're scum bags taking customers for all they've got.
Re: Dealership.
Be careful when you take your car to them for one issue, that they don't try to tell you there are "other" things that your car needs. Manfredi use to own multiple brand dealerships. They sold all of them except for the Chevrolet brand a few years ago. About 4 years ago, my sister had issues with her Toyota Avalon, the check engine light came on, it had 3 different codes. She took the car to Manfredi Toyota and $2,000.00 later the car was repaired. The engine light came back on about 2 months later, it was for the oxygen sensor, on the radiator side, I replaced it and reset the code. 6 months later the same 3 codes, that she originally took it to Toyota came back. They said it was different parts that needed replacement, including the oxygen sensor that I replaced. My sister requested the old parts that were going to be replaced be given to her after the repair. The oxygen sensor they gave her was an "old" rusty one, that was not the one I just put in. They charged her another $1,500.00. I don't trust them, and if you ever google Manfredi and read "reviews" on them, there are many stories like this. Just my 2 cents.
Discussion Starter #8
Re: Dealership.
That's a disgusting way to do business, how unprofessional. Its so difficult to find trustworthy shops but I'll only be going to Manfredi for warranty covered service from now on. I wanted to see if they could solve my leaking sunroof problem but I'll see if I can do it myself. Thank you for sharing your experience with them. Im a bit shocked and disappointed that they'd go that far to screw somebody. I guess thats why people call them "stealerships"
1 - 8 of 8 Posts
About this Discussion
5 Participants
AnnaBu2012
Chevrolet Malibu Forums
Full Forum Listing
