I have read the manual and it says to open the trunk and take out the 2 screws and remove the plastic covering where you will find 2 other screws. Problem is I've searched and I am only seeing 1 screw on the outer plastic covering. Where is the 2nd screw located? I tried to take it off but the plastic wont budge. Suggestions?
the other two screws you are looking for are located inside the trunk. you will have to pull back the carpet cover directly behind the turn signal you want to change and they should be there. all you do is unscrew the covers off the back side of the screws and then take out the one screw you already found on the outside and pull the turn signal assembly straight out from the car and then you should be able to access the bulb unit. Good luck.. I just changed mine and it took all of like 3 minutes maybe not that long.
