I have 2010 Malibu has 88 Miles on it
2.4 LT 6 SPEED
WONT GO FORWARD ONLY REVERSE
PLEASE HELP
WHATS THE PART CAUSE THIS ISSUE
THANKS
This could be a simple issue of the pick up line weld breaking apart . If so it's an easy repair that is not costly . To check drop the pan and visually inspect the tubing at the weld point . If so replace the line .
The 6-speed has no pan. To see any of the internals, you need to remove the trans from the car and take the 2 case halves apart.
The 4-speed, which was eventually dropped during the Gen7 run, has a legacy pan. I wish the 6-speed did, too.
Drive by post....
