Hey guys I currently own a Chevy Malibu 2011 LT i recently installed a brand new dual head unit using a axcess wire harness .however i am having an issue with low volume my subs are off course amplifies by themselves so they generally hit a lot louder however my 4 speakers in the car are playing at a low volume so I looked online n talked to some people and basically everyone is saying I need to bypass my factory amp but o can seem to find it even if there is one I took my whole trunk apart an have included pictures if anyone has any ideas I would be more then grateful
Without a stock amp, you are using high-level inputs with your Rockford Fosgate Prime R500X1D amp. It outputs on only 1 channel, suitable for a sub-woofer.
The RCA inputs are the low-level inputs, and there is a special RF plug for high-level inputs. If your aftermarket HU has only high-level outputs, then you will need to get the special plug for your amp, or an LOC and use the low-level RCA inputs.
