Yes, as soon as I get some time, I will take some pictures for you.
As for the quality of the beam, I am happy, I will show you pictures of the beam hitting a flat white wall and you can see how the cutoff of the beam is sharp (due to it being a projector) however not perfectly straight and angles up on the edges (however not the same on both sides) (not sure if this is normal or not, but adjusting does nothing for it). The lights seem very bright and work well (I can't speak to the bulbs that come with it, as I never used them, I immediatley replaced them with the SilverStar H1's at $20 each).
One thing that is kind of weird is that the low beams and the high beams both use the exact same bulb (an H1 Halogen), my guess would be that this is due to the low beams having the cutoff shade fixed in the light path of the low beam (cannot be adjusted to my knowledge) and therefore they need a separate bulb for the high beams. These high beam bulbs while are the same (H1 Halogen) as the low beam, bulb for bulb, do not have a cut-off shade / lens in front of it from what I can tell.
As for brightness, this is what info I can get that is in a numbers form until I can show you pictures: The stock bulbs in my car (as I would assume would be the same in yours) are basic H11 Halogens which produce 1350 lm ±10% @ 13.2 V. The bulbs that come in these lights are H1 Halogens which produce 1550 lumens ±15% when operated at 13.2 V. I also switched those out like I said to the silverstar H1's which are a brighter white light to help also.
I hope that helps until I can get some pictures up! I love them!
