If you're in the north, did you use -20 blinker fluid? Don't want to forget about it in the fall and have them freeze up.
I have to use the +100. I’m near San Antonio. We get our 3weeks of winter, so I’ll keep that in mind.If you're in the north, did you use -20 blinker fluid? Don't want to forget about it in the fall and have them freeze up.
I’m too cheap to go nitrogen. Do I need a special lube for the mirror? Something that won’t cause a problem with my turbocharger? Or will canola oil work?When you rotated air did you switch to pure nitrogen? Common air is only like 78% nitrogen. If you go pure you gain the difference as 22% better fuel economy. Unfortunately, going pure will only net half the difference as a torque boost so 11%. Remember to lube the hinge on the rear view mirror. When it gets lube it enters HD mode.
