1 - 20 of 23 Posts
Hey All...just sharing my Ride
Here is my 08 Bu
got the V6 in the LS - through a special order
Coco/Cashmere inside
So far the intake is in, sirius is in, kicker 12 inch sub is in and finished up the HID conversion last night (Thanks BigNick for the info )
Heres a few pix from when I first got her...sorry only got pix of the ride and the siruis - I will take more this weekend of the rest.
Also...here is two pix of grill options I am debating over
Thanks for checkin me out everyone
Discussion Starter · #2 ·
some more - the two grills too
thanks again
Discussion Starter · #4 · (Edited)
thanks!
me too - the bars almost look like they are smiling in the middle lol
there's this one too - but It's just mesh inserts
I like the mess grille, think I will order a set for ours.
Why did you order it with a 3.5 instead of the 3.6?
What is the mileage rating with the 3.5?
3.6 wasn't a choice in my particular situation.
not sure of the actual numbers because I dont pay for gas so I dont watch it
but its good when im good and bad when im bad lol
Hey...you're on GMI...I've seen your Malibu...:D
What did the window sticker say? I see the Impala is rated for 29 on the highway when equipped with a 3.5.
It seems like another member has the 3.5 in his 08 Malibu, but his was a fleet car.
The EPA numbers are as follows (city / combined / highway) for the 3.5:
18 / 22 / 29
The numbers for the 3.6 are:
17 / 20 / 26
I pulled these from the www.fueleconomy.gov website, where you can also log your fuel economy numbers for others to compare and use for 'real world' results. I haven't done my new Bu there yet, but did my previous 3 vehicles, and will soon include it. But, as I expected, you give up a bit of power (speaking from experience, a LOT) between the 3.6 and 3.5, but the fuel economy difference is probably worth it. The 3.5 is a good compromise between the 2.4l 4 cyl and the 3.6l 6 cyl for power and fuel economy. And from experience with the previous non-VVT 3500 Malibu, the numbers can be outstanding for highway driving.
Nice car!
Nice ride man, Where in Jersey do you live?
18 / 22 / 29
I pulled these from the www.fueleconomy.gov website, you give up a bit of power (speaking from experience, a LOT) between the 3.6 and 3.5, but the fuel economy difference is probably worth it. The 3.5 is a good compromise between the 2.4l 4 cyl and the 3.6l 6 cyl for power and fuel economy.
I like the power of the 3.6, but like you said it is a good compromise.
I see on the web site the 3.5 is mated to the 4 speed. Just think if they mated the 3.5 to the 6 speed, it would probaly be rated at 31 on the highway.
Discussion Starter · #15 ·
thanks
i liove in somerset - but travel for work all over nj/pa/de/md and beyond lol
so you name it - i have driven through it or past it :eek:
thanks
Oh cool man, I live up in Montague NJ, all the way at the top of NJ, by High Point.
the difference in the 3.5 and 3.6 is much more than the .1 liter. The 3.6 is a variable value timing(VVT) engine and the 3.5 is not. The 3.6 is much newer technology.
I don't believe that's exactly correct either. The original 3500 that was in my 2004 Malibu wasn't VVT, but the one in the newer Malibu's is. However, it's a pushrod (cam in block) engine design, and I'm not certain whether it's VVT on both intake and exhaust (easy to find out, using google, but I don't have the time just now). The 3600 is a dual overhead cam design (weighs more, as a result too, not to mention far larger space needed for it under the hood), and has VVT on both intake and exhaust.
1 - 20 of 23 Posts
