I bought it from [upgradeyourauto] for $95 on Ebay. It snaps on over the original grills.
I bought it from [upgradeyourauto] for $95 on Ebay. It snaps on over the original grills.Looks good!
Where did you get that grill?
Thanks BPizzleyea..definitely looks pretty clean on the malibu..nice job man
KURLY i'm digging that spoiler
Yep I will. I'll take a picture Sat morn and post it for you.KURLY i'm digging that spoiler, can you post a side shot of the spoiler, trying to see how it hangs off the back, and your Bu' looks sweet
The spoiler came with a little bottle of accelerater[ laquer thinner]. I sat the spoiler on the car and with a crayon made an outline of the spoiler. Then I took some alcohol and wiped the paint all the way around the inside of the crayon mark about an inch wide. After that dried [a couple of minutes] I put some accelerater on a peice of cloth an wiped the same area again. Let that dry for a few minutes then peel off the plastic on the spoiler tape and set the spoiler on the car. After you are done you can wipe the crayon off and WAA LAA thats it. NO DRILLING. CAUTION...don't let the accelerater drip on your paint anywhere outside the crayon mark. If it does clean it off immediately.Thanks KURLY, just what I was looking forcan you give a little more info how you mounted it
#1 yesHey KURLY,
thanks for talking your time to share your spoiler information and pics. I will probably get one sometime in the future. Here's some comments/questions for you/the forum:
- do you feel the mounting of the spoiler is sturdy enough to use for closing the trunk across many years of use?
- I saw a guy at my gym who had a 2009 Malibu with a spoiler that did not have the notched out section in the center. next time I see him, I'll ask where he got it.
- Any auto body experts out there who think the spoiler installation will lead to corrosion under the spoiler? I live in the rust belt and used to have a 1979 Camaro. That vehicle had a lot of corrosion under the spoiler, but no rust in the surrounding areas of the body/trunk.
Malo that looks like mine and it is the same company. But when I read the ad it didn't say whether the spoiler was bolted on or glued on with double stick tape. Mine used the tape and is solid as can be. If I can I will add the link. The one exactly like mine is on Ebay right now .KURLY is this the spoiler you have on your Bu'
http://www.sportwing.net/chevroletmalibu08fmspoiler.aspx
