I have a mystery to solve. I wanted new coolant in the 98 V6 first thing I check the manual and it says 13 Quarts or 12 liters. After parking the car on a flat surface I waited for the engine to get cold (~140F) then I removed the coolant tank cap and open the petcock and then the bleed valve with the heater on maximum. The quantity of coolant collected in the catch pan was of 6 quarts or 12 pints or 6 liters and not at all 12 liters or 13 quarts. I looked in the owner`s manual again and it`s 12 liter or 13 quarts. I went back opened the petcock a few drops came out but not even a cup. Then I assumed that the thermostat was stopping some of the liquid so I tried with the hot engine- same result. The coolant does not have solid debris in it but something that looks like oil film. I used water so many times to flush out whatever was in there but it was coming out having same color as the coolant. After night fall I put 6 quarts of dexcoool 50/50 and let it be. Could you give me some suggestions? Thanks
