The EVAP PURGE/VENT should be located under the vehicle back by the fuel tank. Its not the large box that will be back there but a smaller one that will have 2 hoses attached to it.I got a error code on my 08 malibu that says something is wrong with my evap purge/vent. I want to locate it to see if I can change it out myself. Where is the EVAP PURGE/VENT located on my 2008 Malibu LS?
the error code autozone told me wasWhat exactly is the code? EVAP purge and vent are two different operations. The purge solenoid is on top of the engine, near the firewall (follow the EVAP purge tube that runs next to the fuel line up the firewall). The vent solenoid, on the other hand, is on top of the fuel tank on your Malibu.
This sounds like a complicated issue for someone with no experience with cars. Should I just look to take it to a professional?P0446 is generically defined as Evaporative Emission System Vent Control Circuit. Since the ECM on your Malibu can tell a short or open circuit on the EVAP vent control circuit, it really means there's something wrong with the performance of the vent solenoid valve and perhaps the air line between the valve and the EVAP canister. See http://cid-54465800aad91b49.office.live.com/self.aspx/pub/EVAP%20canister%20and%20vent%20solenoid.gif. It shows the removal of the EVAP canister and the EVAP canister vent solenoid (cylindrical component connected to the larger canister) from the driver side of the fuel tank after the fuel tank has been lowered.
Are you sure it's the vent solenoid that's bad? Attached to the fuel tank, right side, about the size of a soup can. You'll need to drop the tank down a bit to get it out. Purge is under the hood and would depend on what engine you have as to exact location. You've ruled out the fuel cap already?anyone done this here? Is the vent solenoid in the same place in the 07 also?
I need to change this out to get my inspection this month![]()
i replaced the gas cap already and i replaced the purge solenoid under the hood because the resistance for the old one seemed to be low enough to be bad. The light is still on though so i guess ill have to drop the tank now. Its only 20 bucks shipped from rock auto but im gonna check the dealer tomorrow to see how much it is. I kinda need this thing now.Are you sure it's the vent solenoid that's bad? Attached to the fuel tank, right side, about the size of a soup can. You'll need to drop the tank down a bit to get it out. Purge is under the hood and would depend on what engine you have as to exact location. You've ruled out the fuel cap already?
On earlier gm's the filler neck was a problem. Not sure if thats the case here or not.Since someone else revived this thread, I have a related question. I have the same same problem and replaced the gas cap, Vent solenoid AND purge solenoid. The check engine light is still on. Does anyone have any idea what else could be the problem?
