You need to pull the plastic cover behind the door handle, there is a 10mm bolt or a phillips head screw. Then there are two hex heads on the arm rest under the rubber strip. Two push pins alond the outer edge of door. The rest of the door is all just plastic clips on the inside, so just start at bottom and pull out. Pull out and up at the top and shazzzam its off. Be sure and unplug the harnesses on window controls and door locks along with the door handle rod so you dont break anything you dont wanna fix. check out pic bellow. This is on my 2010
