Hi everyone, I have a 2015 LT1. I’d like help with a couple of issues that I ran into when trying to service my brakes today.
1. I have done the brakes on my cars for over a decade and I’ve had many different makers and models, but I’ve never had this issue. I am replacing the rear pads and rotors. I could not push the caliper piston back into the caliper. I know it sounds like a very basic step and it usually is. Typically, I use a large C-clamp and the old pad and squeeze the c-clamp to push the piston back. Normally this goes very smoothly. But this piston would not budge; so much so that my cheap harbor freight c-clamp snapped in 2 like a tea biscuit. What am I missing? I did open the cap on the brake fluid reservoir, so that’s not it. Did I forget a key step or do you think it’s seized up?
2. I also have the ABS light on and stabili-trac light on. I had the guy at the auto parts store scan the code and it came up as the left rear ABS sensor. I figured it would be pretty simple. However, accessing the point at which the lead for the sensor plugs into is pretty difficult. Are there tips or tricks on how to get access to that plug in and to disconnect the plug at the end of the lead? I couldn’t get the plug to release from the terminal it plugs in to.
Any advice you have on these issues is greatly appreciated.
Best
Best
