Bought my '07 Malibu SS 3.9L about 6 months ago for a steal because the previous owner was having problems with the traction control light on, hard shifting, and intake air temp codes. Three certified mechanics and hundreds of $ in parts & labor later he gave up & sold it to me for the cost of the new tires on it. I found a wire in the IAT bundle that had a poor butt connection pulled apart. 30 minutes and a properly soldered patch wire later, the OBD IAT codes & traction control light were out and the tranny shifts smooth as silk. (how those 3 things are related is a mystery to me). HOWEVER..............
I am dealing with electrical gremlins (intermittent parasitic battery drain, intermittent high beams not working, intermittent interior courtesy lights) Also experienced a clicking noise heard from somewhere behind the fuse panel on the passenger side console but stopped after I disconnected the battery for a couple of days. The car has an aftermarket security system installed (VIPER model 5701) and I suspect this as the source of the battery drain. The passenger side console fuse box has a red wire (Viper feed?) patched into a 20 amp fuse so I disconnected it and so far the battery has maintained its charge for the last 10 days. The interior light and high beam problems still plague me.
It needs some expected maintenance & repairs; particularly the front suspension (worn out at 147k & clunks a lot on bumpy surfaces like potholes & speed bumps), an oil pressure sensor and some minor body work. I'll be searching the forums for info later.
Otherwise the only problem is this sucker is so smooth and powerful it's wayyy to easy to get to 70mph without realizing it (previous car was a '96 corolla 4cyl). It handles quite well in the corners, brakes firmly & smoothly & is fairly comfortable for me (6'4" & 240#). Fuel consumption is ~17.5 MPG around town. Haven't been on a road trip yet (the covid, ya know!)
