No offense to the people with 20's, but they are a little too big for my liking. I am looking at a set of 19's. Here are the specs for the rims and tires:
Rim Offset = +45mm
Tires = 245-35-19
My concern is that I will be running 3mm closer to the spring perch with this offset (factory is 42mm) and my tire is 30mm wider (2Lt tire width is 215). So in reality, the tire would be 15mm closer to the spring perch with just the tire.
Anyone running after market rims with 245mm wide tires, what offset are the rims you are running? (I hope you are looking SilverLTZ
I dont want to have rubbing issues since I would be getting the rims from the US and I can't return easily (I am in Canada).
Thanks in advance.
Rim Offset = +45mm
Tires = 245-35-19
Thanks in advance.
