Hello all I have a 2012 chevy Malibu
Last week I got the p0013 code, after reading all the related posts here and watched some YouTube videos it seems to be that the Exhaust vvt solenoid is the issue. Bought the replacement part (Dorman), disconnected battery and followed the steps to replace it. Put everything back together. (While I was doing this noticed that the grey clip lock was missing from them im not sure if that makes a difference) The part I bought came with a card suggesting that I change the oil and filter when changing the part, so I did just that went to Valvoline changed the oil with full synthetic and while I was there did the other included tests to check battery, alternator, oil pressure, etc. all was well. Today check engine light returned when starting up car to leave work but this time the codes were p0013 and a c0899 for the abs monitor malfunction/low voltage. I’m stumped now I’ve checked wiring harness and to my naked eye I don’t see any breaks or corrosion and I had my valve cover gasket changed a few months ago and checked the timing chain then and all was well.
