Malibu 2008 2.4 has PO300 and PO171 codes. Installed new spark plugs, fuel injectors, and upstream CO2 sensor. Car does not hold idle and the engine stumbles unless you maintain 2500+ rpms then engine seems to run ok. Fuel pressure is 60 psi. Spark from coils is evident with spark tester. I can't find any evidence of a vacuum leak. Would upgrading my simple obdII tester give me more information then the PO codes? Any suggestions on next diagnostic steps will be appreciated. Thanks.
