Should power steering fluid best checked when engine warmed up or cold? TIA
A azteca9 · Registered Joined Jan 31, 2022 · 13 Posts Discussion Starter · #1 · 3 mo ago Only show this user Should power steering fluid best checked when engine warmed up or cold? TIA
repairman54 · Premium Member Joined Jun 30, 2012 · 3,515 Posts #2 · 3 mo ago Only show this user Dip stick should be marked hot / cold level in most cases. In any case it should be above the Min. mark. and in between Add and Full is acceptable.
A azteca9 · Registered Joined Jan 31, 2022 · 13 Posts Discussion Starter · #3 · 3 mo ago Only show this user Thanks
