Power steering locks up! Rest by turning off ignition.
Thank you for your reply to my ongoing Malibu saga! I also need to replace throttle body. Rough idle. Smelling a faint gas odor when cold starting.Contact GM and report this defect. You may be entitled to a free warranty/recall. Have your VIN handy. If they refuse, report the problem to the NHTSA. This may apply pressure to GM.
Most likely the problem is the steering torque sensor. Although the part is not expensive, a high level scan tool is required to properly calibrate the sensor.
There is also the possibility this defect is caused by some other problem such as a loose wire. Good Luck.
