2006 Malibu LS 2.2.
So I have a weird issue, whenever I am listening to the radio and I plug in the power cable to the power outlet for my phone, which is on a holder on the air vent, it causes interference on the radio stations really bad. Is there any way to solve this?
Try plugging it into the rear power outlet, if you have one.
Try moving the phone around while it's plugged in. It is a 2-way radio and it could be in a spot where certain harmonics are interfering with your car's radio.
If you all figure out what the issue is I would like to know as well.... I have a similar issue when turning on the rear window defogger... radio goes squirrely and I can't hear squat....
Peace
Discussion Starter #6
UPDATE: It was the charging plug itself. I used a different plug with the same charging cable and it solved the problem!
