Any fix for your problem? I have the same and my interior lights don’t come on with the drivers door as well all happened at the same time.Sorry I took so long to reply. I could not find any broken wires in the door jam area. Behind the rubber boot. Again my symptoms are as follows. Radio and accessory lights won’t turn off when car is off and door is opened also driver front window not working. I have changed the accessory relay and window switch.
Sounds like the door jamb switch has failed, or the wires to the switch have failed. I haven't investigated how the malibu detects the door is open, but most cars have a door jamb switch.Any fix for your problem? I have the same and my interior lights don’t come on with the drivers door as well all happened at the same time.
I can't find any photos or instructions on how to fix the door jamb switch if that's the problem online. Info would be greatly appreciated!Door harness in hinge area needs to be inspected for broken wires is what I suspect.
All Data DIY dot com is a good resource. Other members have used it and found it to have a lot of stuff at an affordable cost.I can't find any photos or instructions on how to fix the door jamb switch if that's the problem online. Info would be greatly appreciated!
