Accidentally came across the video of radio removal, posting here in case anyone needs to do it.
http://www.youtube.com/watch?v=NWpQOq0W0U8
the way it should beIt is almost scary how easy it seems to be.
Aye...the head units with a little visible hole on the corners of the face where you insert and it releases? I think the only NA GM vehicle like that right now--it is quite unique because of it--is the Saturn Astra, which is imported. There are a handful of other manufacturer's with them like that, still.the way it should be
but nothing comes close to how easy it was on my Ranger truck. All you needed a couple of wire coat hangers, not even a screwdriverI did it first time within 5 minutes
something like that, yes...there was a special Ford tool for that, but the wire hangers from dry cleaners were good enoughAye...the head units with a little visible hole on the corners of the face where you insert and it releases?
Nothing like bringing a dead post back up, but even the 06 GTO uses similar tools to have the radio out in seconds. I switch between my modded on and stock all the time. I Malibu radio was just as easy to remove.something like that, yes...there was a special Ford tool for that, but the wire hangers from dry cleaners were good enough![]()
