It could definitely be a bad MAF sensor. It could also be wiring to the sensor. There also might be a lot more to the story.
I drove it for a while after this happened, it seems to be ok, kind of slower but yeah it's weird since I literally drove the car yesterday and it was fine. The codes haven't came back after clearing them, I will replace the MAF sensor if this happens again. I'm assuming the barometric sensor is the same as MAF?Since your scan tool says confirmed on the P2227 I would say it has an issue.
It could be affecting the 5v reference signal on the other sensors also. System will limit boost if any intake sensors are acting up to protect the engine. Use only a Genuine GM replacement. Aftermarket sensors are not reliable.
Ok thank you! Hoping that’s all it is. Wiring looked good from what I could see but any idea about the turbo boost sensor problem? Is that on the same sensor as maf?The MAF includes a baro sensor. the MAF technically likes to go by Multifunction Intake Air Sensor in the tech docs. It includes the mass air sensor, intake air humidity, baro, intake air temp.
