Hello and thanks in advance for your time.
I am trying to replace the rear brakes (hoses, calipers, pads and rotors, and passenger side hub/bearing assembly) on a 2010 Malibu.
I am having some trouble figuring out how the pads fit into the calipers, as there seems to be a little nub on the pad which would catch the piston and prevent it from rotating or applying even pressure on the pad.
Two of the pads have 2 nubs, two of the pads have 3rd middle nub. The pads with the middle nub also have the wear indicators. The wear indicators only fit on the inside (piston-side) of the rotor, however it seems like middle nub causes issues with the piston. If the nub his the face of the piston, the only contact the piston has with the pad is the little nub. If the piston is rotated the nub can go in one of the slots to rotate the piston, but then I am concerned with it locking the piston on place so it cannot rotate as the pads wear.
The pads are Raybestos Element 3 EHT1033H.
Has anyone seen this before or know how it is supposed to fit together? Any help is appreciated.
