LT2 . . '08 . . left rear turn signal replacement . . . no big deal.
WRONG!
Getting information from my '08 Malibu Owners Manual, I 'set up' my replacement 'project' by purchasing a #3156 bulb. This was an obstacle against my progress because the PROPER stoplight / turn signal bulb for my LT2 is a #3157. A #3156 is a single filament bulb, and the necessary bulb is a double filament bulb. (I should have realized the error, but the 'truth' didn't register until I finally was able to remove the bulb with the broken filament from the left-side light housing. In this case, the "Replacement Bulb" information in my Manual is incorrect.)
To remove the felt-like cover panel (on the left side of the trunk), the 4 screw-in-convenience-net-fixtures were no problem. The real problem was the removal (and destruction) of the 3 press-fit-plastic-plugs used to additionally secure the cover panel. Then, I found it necessary to remove the interior plastic 'bumper plate' surrounding the trunk lock mechanism.
Including the return trip to the auto parts place to exchange the #3156 bulb for a #3157, the disassembly / reassembly necessary to replace the light took about an hour and fifteen minutes.
I believe the "Taillamps, Turn Signal, and Stoplamps" (page 5-45) in my Owners Manual must relate mainly to the LTZ model.
Now, how do I order replacements for those scraped-out press-fit-plastic-plugs? (One of the convenience-net-fixtures was stripped, also, and that was probably done during plant assembly.) Oh, my! Such an experience for a seemingly simple bulb replacement.
WRONG!
